:Well know that i think about it, i have had my Seat belt light on for about the same time that the problem started but i dont know how that may affect the batt been drain though??
So are you saying the seatbelt light is staing on? If yes then that is your culperit as even a small drain over enough time will flatten the battery. You can do a current draw test by hooking up a multi meter (set to amps) in line with the negative terminal and the negative battery post. You should see a low reading like .4 amps, if higher then you have confirmed yes you have a current draw. Start pulling acc fuses until you see the drain drop....
